Dopo Double Power 7 Speaker Replacement
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: step 1, image 1 of 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: step 2, image 1 of 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: step 3, image 1 of 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: step 4, image 1 of 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: step 5, image 1 of 1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
mike pelosi
682 Reputation
6 Guides authored
UMass Dartmouth, Team 1-2, Miles Fall 2015 Member of UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 190
