Dragon Touch A1x Plus Battery Replacement
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: step 1, image 1 of 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: step 2, image 1 of 2 Dragon Touch A1x Plus Battery  Replacement: step 2, image 2 of 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: step 3, image 1 of 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: step 4, image 1 of 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: step 5, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: step 6, image 1 of 2 Dragon Touch A1x Plus Battery  Replacement: step 6, image 2 of 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Josh Null
313 Reputation
3 Guides authored
IUPUI, Team S5-G5, Baechle Spring 2018 Member of IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Members
6 Guides authored
1 Guide Comment
where can you find a replacement battery for this tablet?
Lupe Rdrgz - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 2,083
