Dragon Touch M10X Camera Replacement
  1. Dragon Touch M10X Camera Replacement, Camera: step 1, image 1 of 2 Dragon Touch M10X Camera Replacement, Camera: step 1, image 2 of 2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Camera Replacement: step 2, image 1 of 1
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Camera Replacement: step 3, image 1 of 2 Dragon Touch M10X Camera Replacement: step 3, image 2 of 2
    • Using your hands and the separating tool, remove the back cover from the device.
  4. Dragon Touch M10X Camera Replacement: step 4, image 1 of 1
    • Using a J0 phillips head bit, remove the single 1 mm screw from the rear facing lens cover.
  5. Dragon Touch M10X Camera Replacement: step 5, image 1 of 1
    • Using a J0 phillips head bit, remove the single 1mm screw from the front facing camera lens cover.
  6. Dragon Touch M10X Camera Replacement: step 6, image 1 of 1
    • Using a plastic opening tool, pry the rear facing camera out of its housing.
  7. Dragon Touch M10X Camera Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Using a plastic opening tool, lift up the latch that attaches the camera's ribbon cable to the device.
    • Using tweezers, pull out the ribbon cable from underneath the latch.
  8. Dragon Touch M10X Camera Replacement: step 8, image 1 of 1
    • Remove the camera strip from the device.
Joseph Rockcliffe
600 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 485
