Dragon Touch MID 7138 Motherboard Replacement
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: step 2, image 1 of 1
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: step 4, image 1 of 1
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: step 5, image 1 of 1
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: step 6, image 1 of 1
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: step 7, image 1 of 2 Dragon Touch MID 7138 Motherboard Replacement: step 7, image 2 of 2
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
Trevor Farkas
101 Reputation
1 Guide authored
IUPUI, Team 2-4, Baechle Spring 2017 Member of IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 592
