Dreamax DMX-ST7A Motherboard Replacement
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: step 2, image 1 of 1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: step 3, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: step 4, image 1 of 1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: step 5, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: step 6, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 6, image 2 of 2
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: step 7, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 7, image 2 of 2
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: step 8, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 8, image 2 of 2
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: How To Solder and Desolder Connections
Stacey Mattila
543 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 321
