Dreamer Autoshade Motor Set Screw Adjustment
  1. Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: step 1, image 1 of 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove motor hub fasteners: step 1, image 2 of 2
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: step 2, image 1 of 2 Dreamer Autoshade Motor Set Screw Adjustment, Remove driver bearing cap: step 2, image 2 of 2
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Dreamer Autoshade Motor Set Screw Adjustment, Tighten Motor Set Screw: step 3, image 1 of 1
    • Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • The hub should fit snugly on the shaft, unable to rotate freely.
    • Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
David
734 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 155
