Dremel 4000 Power Cord Replacement
  1. Dremel 4000 Power Cord Replacement, Back Case: step 1, image 1 of 2 Dremel 4000 Power Cord Replacement, Back Case: step 1, image 2 of 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Power Cord Replacement: step 2, image 1 of 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Power Cord Replacement: step 3, image 1 of 2 Dremel 4000 Power Cord Replacement: step 3, image 2 of 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Power Cord Replacement: step 4, image 1 of 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Power Cord Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Power Cord Replacement: step 6, image 1 of 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Power Cord Replacement, Power Cord: step 7, image 1 of 2 Dremel 4000 Power Cord Replacement, Power Cord: step 7, image 2 of 2
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Power Cord Replacement: step 8, image 1 of 1
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Power Cord Replacement: step 9, image 1 of 1
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Power Cord Replacement: step 10, image 1 of 1
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
5 other people completed this guide.
John Cobb
1,719 Reputation
4 Guides authored
USF Tampa, Team 15-4, Remmell Spring 2016 Member of USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Members
13 Guides authored
One Comment
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 41
All Time: 5,794
