Dremel 7300 MiniMite Cordless Collet Replacement
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: step 1, image 1 of 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: step 1, image 2 of 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: step 1, image 3 of 3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: step 2, image 1 of 3 Dremel 7300 MiniMite Cordless Collet Replacement: step 2, image 2 of 3 Dremel 7300 MiniMite Cordless Collet Replacement: step 2, image 3 of 3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
7 other people completed this guide.
Kat
840 Reputation
3 Guides authored
USF Tampa, Team 3-4, Sullivan Spring 2016 Member of USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Members
4 Guides authored
2 Comments
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Reply
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 32,567
