Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: step 1, image 1 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: step 1, image 2 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: step 1, image 3 of 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: step 2, image 1 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: step 2, image 2 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: step 2, image 3 of 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 3, image 1 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 3, image 2 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 3, image 3 of 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 4, image 1 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 4, image 2 of 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: step 4, image 3 of 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
3 other people completed this guide.
Michael Smith
175 Reputation
1 Guide authored
USF Tampa, Team 3-4, Sullivan Spring 2016 Member of USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 3,162
