Dremel Multipro carbon brush replacement
  1. Dremel Multipro carbon brush replacement, Removal of Carbon Brushes: step 1, image 1 of 1
    • Pull out the power plug
    • Unscrew the two blue caps of the carbon brushes with a slotted screwdriver. Caution: they are under spring tension!
    • Remove the springs
    • Shake out the carbon brushes. If necessary, carefully pull out the round spring guides of the brushes with needle-nose pliers.
  2. Dremel Multipro carbon brush replacement, Assemble: step 2, image 1 of 1
    • Insert carbon brushes with the springs. The alignment of the brushes must match the alignment of the axis! The brushes must be able to smoothly move along the guide.
    • While applying pressure to the springs, check whether the brushes are in contact with the rotor by slowly turning the shaft.
    • Screw the blue cover cap back on.
Function test
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
KaiVi
948 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 45
All Time: 1,377
