Dremel Multipro rotor replacement
  1. Dremel Multipro rotor replacement, Removal of Carbon Brushes: step 1, image 1 of 1
    • Pull out the power plug
    • Unscrew the two blue caps of the carbon brushes with a slotted screwdriver. Caution: they are under spring tension!
    • Remove the springs
    • Shake out the carbon brushes. If necessary, carefully pull out the round spring guides of the brushes with needle-nose pliers.
  2. Dremel Multipro rotor replacement, Assemble: step 2, image 1 of 1
    • Insert carbon brushes with the springs. The alignment of the brushes must match the alignment of the axis! The brushes must be able to smoothly move along the guide.
    • While applying pressure to the springs, check whether the brushes are in contact with the rotor by slowly turning the shaft.
    • Screw the blue cover cap back on.
  3. Dremel Multipro rotor replacement, Open device: step 3, image 1 of 1
    • Unclip the hanger (already removed here)
    • Unscrew thumb cap (already removed here)
    • Remove carbon brushes (see instructions)
    • Remove the 4 Torx screws
    • Remove the housing by lifting it upwards
  4. Dremel Multipro rotor replacement, Rotor removal: step 4, image 1 of 3 Dremel Multipro rotor replacement, Rotor removal: step 4, image 2 of 3 Dremel Multipro rotor replacement, Rotor removal: step 4, image 3 of 3
    • Loosen the Torx screws holding down the tension relief (removal is not necessary)
    • Lift the rotor out of the housing at the front end and pull it out of the housing together with the winding and switch in the direction of the axis towards the front.
    • During this process, the two plug contacts to the electronics will become detached.
    • Remove the rubber bumper around the rear ball bearing.
    • Pull the rotor forward out of the mechanism. The winding and switch do not have to be removed for this (separated in the picture).
  5. Dremel Multipro rotor replacement, Rotor installation: step 5, image 1 of 2 Dremel Multipro rotor replacement, Rotor installation: step 5, image 2 of 2
    • Insert the new rotor into the winding from the front.
    • Slide the rubber bumper onto the rear ball bearing.
    • Slide the rotor along with the winding and the switch into the housing at an angle from the front at the top. Lift the electronics slightly so that the contact pins of the electronics fit into the contacts of the switch.
    • Make sure that the rubber bumper is correctly seated.
    • Make sure that the spring for the shaft lock at the front end is correctly seated.
  6. Dremel Multipro rotor replacement, Reassembly: step 6, image 1 of 1
    • Put housing back on
    • Tighten the 4 Torx screws
    • Install carbon brushes (see instructions)
    • Clip on hanger
    • Reattach thumb rest (not shown here)
Function Test
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
KaiVi
918 Reputation
6 Guides authored
1 Guide Comment
Thanks. You helped me save a 395 Multipro with a seized chuck from the scrap heap.
Jeff Keys - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 36
All Time: 1,126
