Dress Shirt Button Replacement
  1. Dress Shirt Button Replacement, Button: step 1, image 1 of 2 Dress Shirt Button Replacement, Button: step 1, image 2 of 2
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: step 2, image 1 of 3 Dress Shirt Button Replacement: step 2, image 2 of 3 Dress Shirt Button Replacement: step 2, image 3 of 3
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: step 3, image 1 of 2 Dress Shirt Button Replacement: step 3, image 2 of 2
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: step 4, image 1 of 3 Dress Shirt Button Replacement: step 4, image 2 of 3 Dress Shirt Button Replacement: step 4, image 3 of 3
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: step 5, image 1 of 1
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: step 6, image 1 of 3 Dress Shirt Button Replacement: step 6, image 2 of 3 Dress Shirt Button Replacement: step 6, image 3 of 3
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: step 7, image 1 of 3 Dress Shirt Button Replacement: step 7, image 2 of 3 Dress Shirt Button Replacement: step 7, image 3 of 3
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
Your shirt is now ready to be worn again.
2 other people completed this guide.
Jonathan Wong
225 Reputation
1 Guide authored
Cal Poly, Team 28-4, Green Spring 2015 Member of Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 83
All Time: 4,717
