Drill Master Heat Gun Power Switch Replacement
  1. Drill Master Heat Gun Power Switch Replacement, Power Switch: step 1, image 1 of 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Switch Replacement: step 2, image 1 of 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Switch Replacement: step 3, image 1 of 3 Drill Master Heat Gun Power Switch Replacement: step 3, image 2 of 3 Drill Master Heat Gun Power Switch Replacement: step 3, image 3 of 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Switch Replacement: step 4, image 1 of 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Switch Replacement: step 5, image 1 of 1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Switch Replacement: step 6, image 1 of 1
    • Squeeze the tabs on either side of the power switch to remove from the casing.
  7. Drill Master Heat Gun Power Switch Replacement: step 7, image 1 of 2 Drill Master Heat Gun Power Switch Replacement: step 7, image 2 of 2
    • Remove the black, plastic wire protectors from the end of the power switch.
  8. Drill Master Heat Gun Power Switch Replacement: step 8, image 1 of 1
    • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
    • Heating the soldering metal will allow you to pull off the electrical wiring.
    • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 2,837
