Droid Ultra XT1080 Battery Replacement
  1. Droid Ultra XT1080 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the SIM card tray from the side of the device using a plastic opening tool.
  2. Droid Ultra XT1080 Battery Replacement: step 2, image 1 of 1
    • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
    • Work your way from the top and the other side to confirm all the clips are disconnected.
    • Be gentle when performing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Battery Replacement: step 3, image 1 of 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Battery Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Battery Replacement: step 4, image 2 of 2
    • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
  5. Droid Ultra XT1080 Battery Replacement: step 5, image 1 of 1
    • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
  6. Droid Ultra XT1080 Battery Replacement: step 6, image 1 of 1
    • Remove the four T5 Torx screws securing the motherboard.
  7. Droid Ultra XT1080 Battery Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Battery Replacement: step 7, image 2 of 2
    • Gently pry the motherboard out of the frame using the nylon spudger.
    • Make sure not to damage the LCD cable in the process.
  8. Droid Ultra XT1080 Battery Replacement: step 8, image 1 of 1
    • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
3 other people completed this guide.
knoyes
785 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 3,017
