DualShock 2 D-Pad Replacement
  1. DualShock 2 D-Pad Replacement, D-Pad: step 1, image 1 of 3 DualShock 2 D-Pad Replacement, D-Pad: step 1, image 2 of 3 DualShock 2 D-Pad Replacement, D-Pad: step 1, image 3 of 3
    • Turn the controller over.
    • Unscrew the six screws using your Phillips #00 screwdriver.
  2. DualShock 2 D-Pad Replacement: step 2, image 1 of 3 DualShock 2 D-Pad Replacement: step 2, image 2 of 3 DualShock 2 D-Pad Replacement: step 2, image 3 of 3
    • Remove the back cover from the controller.
    • Slide the triggers off by pulling the trigger off the controller and repeat for another side.
  3. DualShock 2 D-Pad Replacement: step 3, image 1 of 3 DualShock 2 D-Pad Replacement: step 3, image 2 of 3 DualShock 2 D-Pad Replacement: step 3, image 3 of 3
    • Remove the circuit board carefully.
    • Make sure not to touch any vital components and only grab them by the side.
  4. DualShock 2 D-Pad Replacement: step 4, image 1 of 3 DualShock 2 D-Pad Replacement: step 4, image 2 of 3 DualShock 2 D-Pad Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the yellow rubber from the D-pad.
    • Remove the black plastic bracket with a pair of tweezers.
  5. DualShock 2 D-Pad Replacement: step 5, image 1 of 3 DualShock 2 D-Pad Replacement: step 5, image 2 of 3 DualShock 2 D-Pad Replacement: step 5, image 3 of 3
    • Remove the broken D-pad from the controller carefully.
  6. DualShock 2 D-Pad Replacement: step 6, image 1 of 3 DualShock 2 D-Pad Replacement: step 6, image 2 of 3 DualShock 2 D-Pad Replacement: step 6, image 3 of 3
    • Put the replacement D-pad in the controller.
    • Make sure to get replacement parts designed for your controller as sizes may vary.
    • Put the plastic bracket back on carefully.
  7. DualShock 2 D-Pad Replacement: step 7, image 1 of 3 DualShock 2 D-Pad Replacement: step 7, image 2 of 3 DualShock 2 D-Pad Replacement: step 7, image 3 of 3
    • Replace the yellow rubber.
    • Carefully insert the circuit board and reclip the triggers.
    • Make sure to insert the analog sticks through the designed opening.
    • Insert the back cover back in place.
  8. DualShock 2 D-Pad Replacement: step 8, image 1 of 3 DualShock 2 D-Pad Replacement: step 8, image 2 of 3 DualShock 2 D-Pad Replacement: step 8, image 3 of 3
    • Screw the back cover on again clockwise.
    • Test D-pad to make sure its in working order.
Enjoy your new D-pad.
7 other people completed this guide.
Gilberto Rosales
337 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 94
Past 30 Days: 377
All Time: 11,210
