DualShock 3 Battery Replacement
  1. DualShock 3 Battery Replacement, Step 1: step 1, image 1 of 3 DualShock 3 Battery Replacement, Step 1: step 1, image 2 of 3 DualShock 3 Battery Replacement, Step 1: step 1, image 3 of 3
    • This is the Dualshock 3 controller
    • On the back of the controller, there will be five 7.2mm Phillips screws securing the body of the controller. (The five screws are circled in black.)
    • Remove each of the five screws from the back of the DualShock controller.
  2. DualShock 3 Battery Replacement, Step 2: step 2, image 1 of 1
    • Push the center of the rear cover (between the two analog sticks) and carefully lift the lower edge away from the rest of the controller.
  3. DualShock 3 Battery Replacement, Step 3: step 3, image 1 of 1
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, but be careful so that you won't pop off the #2 triggers.
    • Here is a DualShock trigger guide on the IFIXIT website in case you need to reattach the #2 triggers.
  4. DualShock 3 Battery Replacement, Step 4: step 4, image 1 of 1
    • Move the battery off the motherboard so you have enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement, Step 5: step 5, image 1 of 2 DualShock 3 Battery Replacement, Step 5: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully pull the battery connector away from the socket that is attached to the motherboard. ( Battery connector is circled in black.)
    • It may be safer to use a tool like tweezers or pliers to pull the battery connector out of the socket.
    • Now you can dispose of the old battery safely. For example taking old used batteries to a household hazardous waste facility.
3 other people completed this guide.
Marcus Aiken
214 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 51
Past 30 Days: 178
All Time: 4,301
