DualShock 3 Motherboard Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. DualShock 3 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
  2. DualShock 3 Motherboard Assembly Replacement: step 2, image 1 of 3 DualShock 3 Motherboard Assembly Replacement: step 2, image 2 of 3 DualShock 3 Motherboard Assembly Replacement: step 2, image 3 of 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
  3. DualShock 3 Motherboard Assembly Replacement: step 3, image 1 of 2 DualShock 3 Motherboard Assembly Replacement: step 3, image 2 of 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
  4. DualShock 3 Motherboard Assembly Replacement: step 4, image 1 of 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,635
