DualShock 4 CHU-ZCT2U Battery Case Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: step 1, image 1 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: step 1, image 2 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement, Outer Shell: step 1, image 3 of 3
    • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
    • Pry the two halves of the shell apart using a plastic opening tool.
    • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  2. DualShock 4 CHU-ZCT2U Battery Case Replacement: step 2, image 1 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement: step 2, image 2 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  3. DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: step 3, image 1 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: step 3, image 2 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement, Battery: step 3, image 3 of 3
    • Unplug the black and red wires from the power port located on the motherboard.
    • Remove the old battery from the controller.
  4. DualShock 4 CHU-ZCT2U Battery Case Replacement: step 4, image 1 of 2 DualShock 4 CHU-ZCT2U Battery Case Replacement: step 4, image 2 of 2
    • Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
  5. DualShock 4 CHU-ZCT2U Battery Case Replacement: step 5, image 1 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement: step 5, image 2 of 3 DualShock 4 CHU-ZCT2U Battery Case Replacement: step 5, image 3 of 3
    • Unhook the battery case from the motherboard, and pull it off.
19 other people completed this guide.
Michelle Joseph
1,819 Reputation
3 Guides authored
USF Tampa, Team S1-G5, Leahy Fall 2017 Member of USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 Members
28 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 12,336
