DualShock 4 Controller Rumble Motors Replacement
  1. DualShock 4 Controller Rumble Motors Replacement, Rumble Motors: step 1, image 1 of 1
    • Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
  2. DualShock 4 Controller Rumble Motors Replacement: step 2, image 1 of 1
    • Remove the rear plate.
    • We recommend using a metal spudger for this step.
  3. DualShock 4 Controller Rumble Motors Replacement: step 3, image 1 of 2 DualShock 4 Controller Rumble Motors Replacement: step 3, image 2 of 2
    • Desolder the joints that attach the rumble motors to the motherboard.
    • For more information on soldering, click here.
  4. DualShock 4 Controller Rumble Motors Replacement: step 4, image 1 of 2 DualShock 4 Controller Rumble Motors Replacement: step 4, image 2 of 2
    • There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
    • Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
  5. DualShock 4 Controller Rumble Motors Replacement: step 5, image 1 of 1
    • Remove the faceplate from the motherboard.
  6. DualShock 4 Controller Rumble Motors Replacement: step 6, image 1 of 3 DualShock 4 Controller Rumble Motors Replacement: step 6, image 2 of 3 DualShock 4 Controller Rumble Motors Replacement: step 6, image 3 of 3
    • With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
13 other people completed this guide.
2 Comments
I’d recommend adding removal instructions for the touchpad also
AlexMorse - Reply
the rumble packs are stuck with an adhesive on my controller. The best way to remove the rumble pack in this case? thanks
Ka Erd - Reply
Past 24 Hours: 7
Past 7 Days: 47
Past 30 Days: 280
All Time: 25,050
