Durofix RV332 Battery Replacement
  1. Durofix RV332 Battery Replacement, Battery: step 1, image 1 of 3 Durofix RV332 Battery Replacement, Battery: step 1, image 2 of 3 Durofix RV332 Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the six 13mm case screws with a #0 phillips screwdriver.
    • Separate the screwdriver housing with a plastic opening tool.
    • Remove battery casing half to expose screwdriver internals.
  2. Durofix RV332 Battery Replacement: step 2, image 1 of 2 Durofix RV332 Battery Replacement: step 2, image 2 of 2
    • Locate battery
    • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
  3. Durofix RV332 Battery Replacement: step 3, image 1 of 1
    • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
    • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
    • Solder the new battery to the stripped wires attached to the printed circuit board.
    • Wrap the newly soldered connections with electrical tape.
3 other people completed this guide.
Brennan Wade
130 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 46
All Time: 3,158
