Dynex DX-WBRDVD1 Optical Drive Replacement
  1. Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: step 1, image 1 of 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Top Cover: step 1, image 2 of 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Optical Drive Replacement: step 2, image 1 of 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Optical Drive Replacement: step 3, image 1 of 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: step 4, image 1 of 2 Dynex DX-WBRDVD1 Optical Drive Replacement, Optical Drive: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
  5. Dynex DX-WBRDVD1 Optical Drive Replacement: step 5, image 1 of 2 Dynex DX-WBRDVD1 Optical Drive Replacement: step 5, image 2 of 2
    • Detach the tape wires from the motherboard and power board.
  6. Dynex DX-WBRDVD1 Optical Drive Replacement: step 6, image 1 of 2 Dynex DX-WBRDVD1 Optical Drive Replacement: step 6, image 2 of 2
    • Lift the disc drive up to a 45 degree angle and pull back out of the device shell
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 444
