Dynex DX-WBRDVD1 Power Supply Board Replacement
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: step 1, image 1 of 2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: step 1, image 2 of 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 2, image 1 of 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 3, image 1 of 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: step 4, image 1 of 2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: step 4, image 2 of 2
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 5, image 1 of 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: step 5, image 2 of 2
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 6, image 1 of 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: step 6, image 2 of 2
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 7, image 1 of 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: step 7, image 2 of 2
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: step 8, image 1 of 1
    • Remove the power supply board.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 713
