Dyson Ball Animal Hose Replacement
Mitchell Klein
Mitchell Klein and 4 other contributors
Last updated on April 9, 2021
3 minutes
Easy
Introduction
Go to step 1
This guide will show how to remove the wand hose in case of a clog, broken seal or other malfunction.
  1. Dyson Ball Animal Hose Replacement, Hose: step 1, image 1 of 2 Dyson Ball Animal Hose Replacement, Hose: step 1, image 2 of 2
    • Turn off power and unplug the vacuum, then turn the vacuum to look at the hose.
  2. Dyson Ball Animal Hose Replacement: step 2, image 1 of 2 Dyson Ball Animal Hose Replacement: step 2, image 2 of 2
    • Turn the red dial counterclockwise and pull up on the wand to remove.
  3. Dyson Ball Animal Hose Replacement: step 3, image 1 of 3 Dyson Ball Animal Hose Replacement: step 3, image 2 of 3 Dyson Ball Animal Hose Replacement: step 3, image 3 of 3
    • Press in the red button where the wand attaches to the hose and pull apart.
  4. Dyson Ball Animal Hose Replacement: step 4, image 1 of 1
    • Remove the main canister by pressing the red release button and pulling up and away.
  5. Dyson Ball Animal Hose Replacement: step 5, image 1 of 3 Dyson Ball Animal Hose Replacement: step 5, image 2 of 3 Dyson Ball Animal Hose Replacement: step 5, image 3 of 3
    • Grip the base of the hose so your thumb reaches around to press the red tab shown.
    • Push the red tab at towards the hose while pulling the hose upwards.
    • With some wiggling, it will come out.
15 other people completed this guide.
Mitchell Klein
911 Reputation
2 Guides authored
Cal Poly, Team S15-G5, Banghart Spring 2017 Member of Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Members
17 Guides authored
9 Comments
I used the hose and attachments on my ball animal + up13 and after removal of attachment and stowing the hose to the handle assy. , I can not get the vacumm to stop sucking from the top of the handle? I’ve attempted reading the owners manual (which is not user friendly) and also watched Youtube demonstrations with no luck. This has been two days of struggling with no success???
james gaspard - Reply
The suction is diverted to the hose when the machine is upright. Stand behind the machine, pull the handle towards you and the transfer valve automatically diverts the suction to the brush head. Put it back into the upright position and suction automatically diverts to the rear hose.
mike.vardy - Reply
can anyone show me a picture of the transfer valve? I think it is not going into position when I try to use the wand.
Rita & Chuck Mergen - Reply
it looks like the wand has a round plastic device in middle is this correct? i have taken the wand out of the hose and the hose has suction but when all goes back together and turn on the hand held wand device has no suction
woody jones - Reply
Awesome! Worked like a charm. I had sucked up one of the cat's toys. I was able to remove the little toy and the hose works again.
Thank you!
jboyd5322 - Reply
Past 24 Hours: 121
Past 7 Days: 413
Past 30 Days: 861
All Time: 139,687
