Dyson Ball Animal Hose Replacement
Introduction
Go to step 1This guide will show how to remove the wand hose in case of a clog, broken seal or other malfunction.
Grip the base of the hose so your thumb reaches around to press the red tab shown.
Push the red tab at towards the hose while pulling the hose upwards.
Hose will not release.
The dyson up20 does not have a clip on the hose. You have to turn the base of the hose counterclockwise to remove and clockwise to install.
I have the dyson cinematic animal ball, and I cannot get the hose to release also, I tried the red tab, tried twisting etc nothing works
I used a pair of needle nose pliers to hold the red tab pulling up and toward the hose
No suction from wand assembly even when hose taken off, all openings checked, all filters cleaned x7 years. I have had this vacuum for about 7 years- it’s barely used because 6 1/2 of those years it doesn’t bloody work. Never buying a Dyson ever again. After 3 months of owning it I bought another vacuum because there is ALWAYS something wrong with it. The hose part hasn't worked since the third month of owning it. It rarely stands up. It won’t switch suction from bottom to hose. Oh yes lots of suction! But that does you a fat lot of good when it does not suck out the wand or the bottom.
15 other people completed this guide.
9 Comments
I used the hose and attachments on my ball animal + up13 and after removal of attachment and stowing the hose to the handle assy. , I can not get the vacumm to stop sucking from the top of the handle? I’ve attempted reading the owners manual (which is not user friendly) and also watched Youtube demonstrations with no luck. This has been two days of struggling with no success???
The suction is diverted to the hose when the machine is upright. Stand behind the machine, pull the handle towards you and the transfer valve automatically diverts the suction to the brush head. Put it back into the upright position and suction automatically diverts to the rear hose.
can anyone show me a picture of the transfer valve? I think it is not going into position when I try to use the wand.
it looks like the wand has a round plastic device in middle is this correct? i have taken the wand out of the hose and the hose has suction but when all goes back together and turn on the hand held wand device has no suction
Thank you!! I had a couple coins stuck in the wand and this showed me perfectly how to access them and clear the blockage. MUCH appreciated!!🙏🏾
