Dyson Ball Animal Power Button Replacement
  1. Dyson Ball Animal Power Button Replacement, Power Button: step 1, image 1 of 2 Dyson Ball Animal Power Button Replacement, Power Button: step 1, image 2 of 2
    • Turn off and unplug the vacuum
  2. Dyson Ball Animal Power Button Replacement: step 2, image 1 of 1
    • Press the red release button and pull the canister up and away.
  3. Dyson Ball Animal Power Button Replacement: step 3, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 3, image 2 of 2
    • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
  4. Dyson Ball Animal Power Button Replacement: step 4, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 4, image 2 of 2
    • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
  5. Dyson Ball Animal Power Button Replacement: step 5, image 1 of 3 Dyson Ball Animal Power Button Replacement: step 5, image 2 of 3 Dyson Ball Animal Power Button Replacement: step 5, image 3 of 3
    • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
  6. Dyson Ball Animal Power Button Replacement: step 6, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 6, image 2 of 2
    • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
    • Upon removal of this case, you will be able to see a red circular power button.
  7. Dyson Ball Animal Power Button Replacement: step 7, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 7, image 2 of 2
    • Gently pull the power button out of its slot as shown.
    • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
4 other people completed this guide.
Hank Wai
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 7,891
