Dyson DC08 brush replacement
  1. Dyson DC08 brush replacement, Brush: step 1, image 1 of 3 Dyson DC08 brush replacement, Brush: step 1, image 2 of 3 Dyson DC08 brush replacement, Brush: step 1, image 3 of 3
    • Take off the dust cannister.
    • Remove the suction hose.
  2. Dyson DC08 brush replacement: step 2, image 1 of 3 Dyson DC08 brush replacement: step 2, image 2 of 3 Dyson DC08 brush replacement: step 2, image 3 of 3
    • Extract the front filter.
  3. Dyson DC08 brush replacement: step 3, image 1 of 3 Dyson DC08 brush replacement: step 3, image 2 of 3 Dyson DC08 brush replacement: step 3, image 3 of 3
    • Extract the rear filter.
    • Unscrew the first Torx screw.
  4. Dyson DC08 brush replacement: step 4, image 1 of 2 Dyson DC08 brush replacement: step 4, image 2 of 2
    • Optionally, remove the rear filter cover.
  5. Dyson DC08 brush replacement: step 5, image 1 of 2 Dyson DC08 brush replacement: step 5, image 2 of 2
    • Unscrew the 2nd Torx screw.
    • Disassemble the suction hose connection (optional)
  6. Dyson DC08 brush replacement: step 6, image 1 of 3 Dyson DC08 brush replacement: step 6, image 2 of 3 Dyson DC08 brush replacement: step 6, image 3 of 3
    • Remove the wheels.
    • The wheels clip onto the body of the appliance.
    • Unscrew the 4 Torx screws (two in the right and two on the left).
  7. Dyson DC08 brush replacement: step 7, image 1 of 2 Dyson DC08 brush replacement: step 7, image 2 of 2
    • Open the body of the vacuum cleaner.
    • You can use a multimeter to test the switch.
    • Disconnect the brown wire at the switch.
    • Disconnect the blue wire at the single connector by the motor.
    • Lift out the motor.
  8. Dyson DC08 brush replacement: step 8, image 1 of 2 Dyson DC08 brush replacement: step 8, image 2 of 2
    • Open the motor housing (4 clips).
    • Remover the motor from its plastic casing.
    • Disconnect the motor.
  9. Dyson DC08 brush replacement: step 9, image 1 of 3 Dyson DC08 brush replacement: step 9, image 2 of 3 Dyson DC08 brush replacement: step 9, image 3 of 3
    • disassembly of 2 engine coals (1 Phillips screw per coal)
  10. Dyson DC08 brush replacement: step 10, image 1 of 3 Dyson DC08 brush replacement: step 10, image 2 of 3 Dyson DC08 brush replacement: step 10, image 3 of 3
    • Worn brush.
    • Opening the brush housing.
  11. Dyson DC08 brush replacement: step 11, image 1 of 3 Dyson DC08 brush replacement: step 11, image 2 of 3 Dyson DC08 brush replacement: step 11, image 3 of 3
    • Extraction of the brush and spring.
  12. Dyson DC08 brush replacement: step 12, image 1 of 2 Dyson DC08 brush replacement: step 12, image 2 of 2
    • Removing the brush.
  13. Dyson DC08 brush replacement: step 13, image 1 of 2 Dyson DC08 brush replacement: step 13, image 2 of 2
    • Soldering a new brush.
17 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
christophe
806 Reputation
2 Guides authored
16 Guide Comments
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - Reply Share
Hi, where did you buy the new motor?
Nadja - Share
Bravo, très bon tutoriel
shog shog - Reply Share
Bonjour
et si on n’a rien pour souder, y a t’il une autre solution svp?
GALLAS - Reply Share
Bonjour ! Si vous ne disposez pas de matérial de soudure, nous vous conseillons de vous rendre à un Repair Café ou un Fab Lab. Ces associations mettent du matériel à disposition et peuvent éventuellement aussi vous conseiller sur la démarche à suivre. Bonne réparation !
Claire Miesch - Share
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 206
All Time: 20,519
