Dyson DC28 Animal Post/Pre Filter Assemblies Replacement
  1. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement, Post/Pre Filter Assemblies: step 1, image 1 of 1
    • Find and press firmly on the red button located above the dust chamber.
    • Hold the handle and pull away from the vacuum base when the button releases the dust chamber.
    • Set off to the side.
  2. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: step 2, image 1 of 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: step 2, image 2 of 2
    • Find and firmly press the purple buttons on each side of the pre filter assembly.
    • When the button releases the filter and its casing, lift straight out of vacuum base.
    • After removing the filter in its casing, hold the case with one hand while gently prying the filter out with your other hand.
  3. Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: step 3, image 1 of 2 Dyson DC28 Animal Post/Pre Filter Assemblies Replacement: step 3, image 2 of 2
    • Find the tab for the post filter cap and pull away from base of vacuum to release the top.
    • When the cap has been swung out of the way, pry the post filter out gently (using same technique as before with pre filter).
3 other people completed this guide.
Quentin Klueter
164 Reputation
1 Guide authored
Cal Poly, Team 21-4, Maness Winter 2017 Member of Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,930
