Dyson DC39 Origin Steering Assembly Replacement
  1. Dyson DC39 Origin Steering Assembly Replacement, Bin: step 1, image 1 of 3 Dyson DC39 Origin Steering Assembly Replacement, Bin: step 1, image 2 of 3 Dyson DC39 Origin Steering Assembly Replacement, Bin: step 1, image 3 of 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: step 2, image 1 of 3 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: step 2, image 2 of 3 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: step 2, image 3 of 3
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Steering Assembly Replacement: step 3, image 1 of 3 Dyson DC39 Origin Steering Assembly Replacement: step 3, image 2 of 3 Dyson DC39 Origin Steering Assembly Replacement: step 3, image 3 of 3
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
Luke Matusiak
479 Reputation
3 Guides authored
Cal Poly, Team S23-G6, Livingston Spring 2017 Member of Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Members
6 Guides authored
1 Guide Comment
Thank you, thank you, thank you!
Robin Hill - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 905
