Dyson DC56 Cyclone Replacement
  1. Dyson DC56 Cyclone Replacement, Dust Bin: step 1, image 1 of 1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Cyclone Replacement: step 2, image 1 of 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Cyclone Replacement: step 3, image 1 of 1
    • Separate the device with the purple button.
  4. Dyson DC56 Cyclone Replacement: step 4, image 1 of 1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Cyclone Replacement: step 5, image 1 of 1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Cyclone Replacement: step 6, image 1 of 1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Cyclone Replacement: step 7, image 1 of 1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Cyclone Replacement, Cyclone: step 8, image 1 of 1
    • Use a T8-Torque screwdriver to remove the 18mm screw from the back of the Cyclone.
  9. Dyson DC56 Cyclone Replacement: step 9, image 1 of 1
    • Remove the bottom of the cyclone screen by twisting it to the left and pulling down.
  10. Dyson DC56 Cyclone Replacement: step 10, image 1 of 1
    • Remove the rest of the cyclone screen by pulling down.
  11. Dyson DC56 Cyclone Replacement: step 11, image 1 of 1
    • Locate and take out the six 26mm screws with a T-8 Torque screwdriver.
    • Once you have removed the screws you can remove the rest of the Cyclone.
John Czerkawski
427 Reputation
4 Guides authored
USF Tampa, Team S10-G1, Thompson Fall 2017 Member of USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Members
11 Guides authored
1 Guide Comment
I can’t remove the cyclone screen. Any tricks to removing?
J M - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 1,121
