Dyson DC56 Motor Replacement
  1. Dyson DC56 Motor Replacement, Battery: step 1, image 1 of 1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Motor Replacement: step 2, image 1 of 1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Motor Replacement: step 3, image 1 of 1
    • Separate the device with the purple button.
  4. Dyson DC56 Motor Replacement: step 4, image 1 of 1
    • Take out the filter.
  5. Dyson DC56 Motor Replacement: step 5, image 1 of 1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Motor Replacement, Battery screw 2: step 6, image 1 of 1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Motor Replacement: step 7, image 1 of 1
    • Pull the battery pack down and away from the main body and remove it from the device.
  8. Dyson DC56 Motor Replacement, Motor: step 8, image 1 of 1
    • Take out the 10mm screw using a Phillips #1 screwdriver.
  9. Dyson DC56 Motor Replacement: step 9, image 1 of 1
    • Use a spudger to separate the back plate covering the motor.
    • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
  10. Dyson DC56 Motor Replacement: step 10, image 1 of 1
    • Use a flat spudger to loosen and remove the motor out of the vacuum.
2 other people completed this guide.
John Czerkawski
427 Reputation
4 Guides authored
USF Tampa, Team S10-G1, Thompson Fall 2017 Member of USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 2,812
