Dyson V6 Motorhead Motor Replacement
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: step 1, image 1 of 2 Dyson V6 Motorhead Motor Replacement, Collection Bin: step 1, image 2 of 2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: step 2, image 1 of 2 Dyson V6 Motorhead Motor Replacement: step 2, image 2 of 2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: step 3, image 1 of 3 Dyson V6 Motorhead Motor Replacement: step 3, image 2 of 3 Dyson V6 Motorhead Motor Replacement: step 3, image 3 of 3
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: step 4, image 1 of 1
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: step 5, image 1 of 2 Dyson V6 Motorhead Motor Replacement: step 5, image 2 of 2
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: step 6, image 1 of 2 Dyson V6 Motorhead Motor Replacement: step 6, image 2 of 2
    • Detach the motor from the remaining motor head assembly.
10 other people completed this guide.
Addie Hedge
710 Reputation
5 Guides authored
Cal Poly, Team 22-6, Maness Winter 2017 Member of Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Members
5 Guides authored
3 Comments
really good can understand and not too technical
kelvin - Reply
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - Reply
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 43
All Time: 18,947
