Dyson V8 Animal Battery Replacement
  1. Dyson V8 Animal Battery Replacement, Bin: step 1, image 1 of 2 Dyson V8 Animal Battery Replacement, Bin: step 1, image 2 of 2
    • Push the red button and slide the connecting shaft off.
    • The shaft must be held from moving when disconnecting from the motor.
  2. Dyson V8 Animal Battery Replacement: step 2, image 1 of 3 Dyson V8 Animal Battery Replacement: step 2, image 2 of 3 Dyson V8 Animal Battery Replacement: step 2, image 3 of 3
    • Pull up on the red tab and continue to slide the motor completely up.
    • The dust bin will open on the bottom.
  3. Dyson V8 Animal Battery Replacement: step 3, image 1 of 2 Dyson V8 Animal Battery Replacement: step 3, image 2 of 2
    • Push the red tab down.
    • Pull the dust bin out from the handle head.
  4. Dyson V8 Animal Battery Replacement, Battery: step 4, image 1 of 2 Dyson V8 Animal Battery Replacement, Battery: step 4, image 2 of 2
    • Push down on the red tab.
  5. Dyson V8 Animal Battery Replacement: step 5, image 1 of 2 Dyson V8 Animal Battery Replacement: step 5, image 2 of 2
    • Push down on the red tab on the other side.
    • Pull the motor away from the handle.
    • You may need to hold down the handle while sliding the motor off.
  6. Dyson V8 Animal Battery Replacement: step 6, image 1 of 2 Dyson V8 Animal Battery Replacement: step 6, image 2 of 2
    • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
  7. Dyson V8 Animal Battery Replacement: step 7, image 1 of 1
    • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
  8. Dyson V8 Animal Battery Replacement: step 8, image 1 of 2 Dyson V8 Animal Battery Replacement: step 8, image 2 of 2
    • Slide the battery out from handle.
    • The handle must be held from moving while sliding the battery out.
12 other people completed this guide.
AJ McLean-Scholz
753 Reputation
5 Guides authored
Cal Poly, Team S19-G1, White Winter 2020 Member of Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Members
10 Guides authored
5 Comments
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - Reply
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - Reply
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - Reply
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - Reply
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - Reply
Past 24 Hours: 7
Past 7 Days: 54
Past 30 Days: 176
All Time: 8,998
