Dyson V8 Animal Battery Replacement
AJ McLean-Scholz
AJ McLean-Scholz and 5 other contributors
Last updated on January 30, 2025
2 - 5 minutes
Easy
Introduction
Go to step 1
If your Dyson V8 Animal’s battery fails to charge or turn the vacuum on, use this guide to replace the battery. The battery is used to power the vacuum. A broken or worn-out battery may fail to turn the vacuum on or charge.
Before using this guide check that your battery does not just need to be charged and refer to The Devices LED Flashes troubleshooting page for more information on troubleshooting your battery.
No special skills are required for this guide.
Before beginning, make sure to turn off the vacuum and disconnect it from any external power source.
Parts
Tools
Show more…
  1. Dyson V8 Animal Battery Replacement, Bin: step 1, image 1 of 2 Dyson V8 Animal Battery Replacement, Bin: step 1, image 2 of 2
    • Push the red button and slide the connecting shaft off.
    • The shaft must be held from moving when disconnecting from the motor.
  2. Dyson V8 Animal Battery Replacement: step 2, image 1 of 3 Dyson V8 Animal Battery Replacement: step 2, image 2 of 3 Dyson V8 Animal Battery Replacement: step 2, image 3 of 3
    • Pull up on the red tab and continue to slide the motor completely up.
    • The dust bin will open on the bottom.
  3. Dyson V8 Animal Battery Replacement: step 3, image 1 of 2 Dyson V8 Animal Battery Replacement: step 3, image 2 of 2
    • Push the red tab down.
    • Pull the dust bin out from the handle head.
  4. Dyson V8 Animal Battery Replacement, Battery: step 4, image 1 of 2 Dyson V8 Animal Battery Replacement, Battery: step 4, image 2 of 2
    • Push down on the red tab.
  5. Dyson V8 Animal Battery Replacement: step 5, image 1 of 2 Dyson V8 Animal Battery Replacement: step 5, image 2 of 2
    • Push down on the red tab on the other side.
    • Pull the motor away from the handle.
    • You may need to hold down the handle while sliding the motor off.
  6. Dyson V8 Animal Battery Replacement: step 6, image 1 of 2 Dyson V8 Animal Battery Replacement: step 6, image 2 of 2
    • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
  7. Dyson V8 Animal Battery Replacement: step 7, image 1 of 1
    • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
  8. Dyson V8 Animal Battery Replacement: step 8, image 1 of 2 Dyson V8 Animal Battery Replacement: step 8, image 2 of 2
    • Slide the battery out from handle.
    • The handle must be held from moving while sliding the battery out.
12 other people completed this guide.
AJ McLean-Scholz
753 Reputation
5 Guides authored
Cal Poly, Team S19-G1, White Winter 2020 Member of Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Members
10 Guides authored
5 Comments
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - Reply
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - Reply
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - Reply
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - Reply
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - Reply
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 177
All Time: 9,002
