Dyson v6 Absolute Cyclone Replacement
  1. Dyson v6 Absolute Cyclone Replacement, Bin: step 1, image 1 of 1
    • Unplug the device.
  2. Dyson v6 Absolute Cyclone Replacement: step 2, image 1 of 1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Cyclone Replacement: step 3, image 1 of 1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Cyclone Replacement: step 4, image 1 of 1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Cyclone Replacement, Main Body: step 5, image 1 of 1
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Cyclone Replacement: step 6, image 1 of 1
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Cyclone Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Cyclone Replacement: step 8, image 1 of 2 Dyson v6 Absolute Cyclone Replacement: step 8, image 2 of 2
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Dyson v6 Absolute Cyclone Replacement, Cyclone: step 9, image 1 of 1
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Dyson v6 Absolute Cyclone Replacement: step 10, image 1 of 2 Dyson v6 Absolute Cyclone Replacement: step 10, image 2 of 2
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Dyson v6 Absolute Cyclone Replacement: step 11, image 1 of 1
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
17 other people completed this guide.
Tabitha Espina Velasco
3,702 Reputation
5 Guides authored
3 Guide Comments
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
John Griggs - Reply
Das Zyklon läßt sich noch viel weiter zerlegen!
Tom - Reply
Schmutz/Staub an den Plastikteilen nach Zerlegung lassen sich gut im Eimer mit Seifenwasser auflösen.
Wieder zusammenbauen erst nach kompletten Trocknen !
Macht mal Fotos von verdrecktem Zyklon.
RepairUli - Reply
Past 24 Hours: 9
Past 7 Days: 57
Past 30 Days: 234
All Time: 24,442
