E-bike Disassembly of frame for painting (model: HNF UD1)
  1. E-bike Disassembly of frame for painting (model: HNF UD1), Remove E-bike Battery: step 1, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Remove E-bike Battery: step 1, image 2 of 2
    • Unlock the battery
    • Remove the Battery
    • You may fetch a box to store all the parts of the bike while it is taken for painting
    • Great videos about dissasembly of Bosch ebike parts can be found here: https://www.e-bikeshop.co.uk/Bosch-eBike...
  2. E-bike Disassembly of frame for painting (model: HNF UD1), Remove the Seatpost and seatpost clamp: step 2, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the Seatpost and seatpost clamp: step 2, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the Seatpost and seatpost clamp: step 2, image 3 of 3
    • If you use a bike stand, this may rather be the last step!
    • Unscrew the seatpost clamp screw with the 5mm hex key
    • Remove the seat and seat post
    • Pull off the seatpost clamp
  3. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Crank arm: step 3, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Crank arm: step 3, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Crank arm: step 3, image 3 of 3
    • Remove the crank arm bolt with 8mm allen key completely
    • A significant amount of pressure may be needed at the beggining. You may hold the crank arm for better force
    • Before removeing the drive unit its best to check this video for a general overview: https://www.e-bikeshop.co.uk/Bosch-eBike...
  4. E-bike Disassembly of frame for painting (model: HNF UD1): step 4, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 4, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 4, image 3 of 3
    • Install Crank extractor tool
    • screw the extractor tool gently in
    • it is designed to go in nice and smooth, by hand!
    • hand tighten the rear portion of the crank extractor
    • With the 16 mm wrench rotate clockwise
    • Remove the extractor tool
    • Repeat on the other side
  5. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Chain ring - not necessary: step 5, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Chain ring - not necessary: step 5, image 2 of 2
    • Hold the back brake (or hold it in place with a zip tie)
    • So the back wheel cant move, and the carbon belt holds the chain ring in place
    • with the Bosch chain ring lock ring removal tool on a 1/2" ratchet loosen the lock ring on the chain ring
    • To loosen one needs to turn it to the right! (clockwise) [it is the opposite direction than usual]
    • A significant force is needed to loosen the lockring
    • In a later step, after the carbon belt is removed, the chain ring can easily be pulled down too
    • The text must face outwards both on the chainring and the lockring
  6. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Belt guide: step 6, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Belt guide: step 6, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Belt guide: step 6, image 3 of 3
    • With the help of a Philips 1 screwdriver remove the tiny screw holding the plastic guide in place
    • After the screw is removed the plastic can be slid off to the side
  7. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Chain ring: step 7, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Chain ring: step 7, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Chain ring: step 7, image 3 of 3
    • Loosen the back wheel bolts with the 15mm wrench on both sides of the rear axel and move the rear wheel out vertically for a few centimeters
    • Thus no tension is on the belt
    • slide the belt and chain ring off the drive train axel
    • Do not put too big force on belt (bending etc)
    • Slide the remaining double metal ring off
    • Slide the underlying black sealing ring off
  8. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit Cover: step 8, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit Cover: step 8, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit Cover: step 8, image 3 of 3
    • On the right side:
    • Remove the 2 screws closer to the front with the help of a 3mm hex key
    • When the plastic is a bit loose, a black plastic distance holder can be slid out from between the frame and plastic cover
  9. E-bike Disassembly of frame for painting (model: HNF UD1): step 9, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 9, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 9, image 3 of 3
    • Proceed using a T25 torx screwdriver to remove the 2 screws holding the plastic cover in place on the right side of the frame
    • approximately where earlier the belt placeholder was
    • After all these screws (4 in total on this side) are removed, the plastic cover can be lifted and removed
    • Proceed to the other side
  10. E-bike Disassembly of frame for painting (model: HNF UD1): step 10, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 10, image 2 of 2
    • On the left side of the frame:
    • Using the 3mm hex key, remove the small screw in the deep hole
    • This screw has a length of 11,5mm
  11. E-bike Disassembly of frame for painting (model: HNF UD1): step 11, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 11, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 11, image 3 of 3
    • Remove the two (identical) lower screws with the 3mm hex key
    • On this bike type, the frame could take bigger screws, thats why the first screw has a longer "neck". In one case this came out directly, when unscrewing the screw.
    • If this extra does not come out, then it can be removed with a big flat head screwdriver (size 8) later on, but must not necessary be removed
    • These screws are 17,5 mm long
    • Lift off the plastic cover
  12. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit holder: step 12, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit holder: step 12, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch Drive unit holder: step 12, image 3 of 3
    • Since the frame holds the unit in place, the drive unit holder screws can be removed before the cables are
    • However, make sure, the drive unit does not fall out of place!
    • Remove the two torx screws with a T30 torx screwdriver
  13. E-bike Disassembly of frame for painting (model: HNF UD1): step 13, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 13, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 13, image 3 of 3
    • Remove the two nuts with a 13mm socket and ratchet
  14. E-bike Disassembly of frame for painting (model: HNF UD1), Disconnect Bosch drive unit cables: step 14, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Disconnect Bosch drive unit cables: step 14, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Disconnect Bosch drive unit cables: step 14, image 3 of 3
    • Never pull directly on the cables!
    • Remove the biggest cable, the battery cable:
    • Using a flat head screwdriver loosen the catch 1-2mm
    • Using pliers disconnect the plug of the powerpack
  15. E-bike Disassembly of frame for painting (model: HNF UD1): step 15, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 15, image 2 of 2
    • These images show how the original cableing was and serves as a reminder of all 4+1 plugs in place (battery pack plug is disconnected already)
  16. E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of back lamp: step 16, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of back lamp: step 16, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of back lamp: step 16, image 3 of 3
    • Located in 3. place from the left is the back lamp's cable and plug
    • It runs directly to the back of the bike and exits the drive units frame part on a hole around the kickstand just below the rear fender
    • The cable runs through the inner side of the rear fender and ends in the back lamp
  17. E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of Bosch sensor: step 17, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of Bosch sensor: step 17, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove plug and cable of Bosch sensor: step 17, image 3 of 3
    • From the 4. socket remove the plug of the bosch sensor
    • The cable goes directly inside the left back fork and exits just before the sensors place
  18. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Plug going to intuvia board computer: step 18, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Plug going to intuvia board computer: step 18, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Plug going to intuvia board computer: step 18, image 3 of 3
    • Remove the flat plug and unwind the cables
    • The cable enters the inside of the frame in the middle and exits on the left side on the biggest hole, runs up the frame and to the board computer mount
  19. E-bike Disassembly of frame for painting (model: HNF UD1), Remove the plug of the front light: step 19, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the plug of the front light: step 19, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the plug of the front light: step 19, image 3 of 3
    • The first socket is for the front light and goes straight throw the middle of the frame, and out on the biggest whole
    • Runs along the fork and up to the light
  20. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Drive Unit: step 20, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Drive Unit: step 20, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Drive Unit: step 20, image 3 of 3
    • When all plugs are unplugged, the last nut can also be loosened with the 13mm socket
    • The drive unit can be shifted horizontally to the other side.
  21. E-bike Disassembly of frame for painting (model: HNF UD1), Drive unit removal: step 21, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Drive unit removal: step 21, image 2 of 2
    • Keep the long place holder on the two long screws on top of the drive unit
    • Keep small place holder on the lower long screw as well!
  22. E-bike Disassembly of frame for painting (model: HNF UD1), Remove the black design cover: step 22, image 1 of 1
    • Remove the screw next to the battery charging port with a PH1 Screwdriver [marked with red circle]
    • This screw is the smallest of the three types
    • Remove the upper screw with a 3 mm hex key on both sides. (2x in total) [marked with blue circle on this side]
    • These screws are slightly longer and thinner, than the lowest screws
  23. E-bike Disassembly of frame for painting (model: HNF UD1): step 23, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 23, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 23, image 3 of 3
    • Remove the lower screw on one side.
    • This lower screw is thicker and shorter, than the upper hex screw
    • The screw on the other side can also be removed, however its better left and simply shifted to the side (there is a spacer inbetween held in place with these two screws)!
    • After the 4 screws are removed, the black cover can be taken off (comes in two pieces) sideways
  24. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Battery Mounting Cover: step 24, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Battery Mounting Cover: step 24, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Battery Mounting Cover: step 24, image 3 of 3
    • For removing the plastic cover of lower battery holding part
    • Remove the two black screws from the black plastic with a T15 torx screwdriver
    • Release the catch on the lower side (facing the back fork/drive unit)
    • By taking the plastic parts apart, the outer shell can be removed
  25. E-bike Disassembly of frame for painting (model: HNF UD1), Remove the battery plug: step 25, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the battery plug: step 25, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the battery plug: step 25, image 3 of 3
    • First remove the cables with smaller plugs through the rectangular hole
    • Carefully, not to bend (and break) cables and plugs
    • After all other cables removed, the battery plug fits the big hole on its own
  26. E-bike Disassembly of frame for painting (model: HNF UD1): step 26, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 26, image 2 of 2
    • Remove the two torx screws with a T25 torx screwdriver
  27. E-bike Disassembly of frame for painting (model: HNF UD1): step 27, image 1 of 1
    • For the upper cover
    • Using the T15 torx screwdriver remove the black screw from the low end
    • lift the cover gently (lift outwards around the lock)
    • after fidgeting around, lifting the right side helped
  28. E-bike Disassembly of frame for painting (model: HNF UD1): step 28, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 28, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 28, image 3 of 3
    • With the help of a T25 screwdriver, remove the two screws holding the upper (locking mechanism) to the frame
    • When both screws are removed, the lock can be lifted (removed)
    • The plus is on the upper side
    • Underlying cable holder plastic can also be lifted
    • the higher fences show to the upper side, also the narrower side is on the top
    • There may be a plate under the lower screw between the frame and the lock (10)
    • But could also be below the upper one (04)
  29. E-bike Disassembly of frame for painting (model: HNF UD1), Remove front brake lever for easier handling: step 29, image 1 of 1
    • Remove grip on right side
    • Loosen the brake lever and pull it off the handle
    • Alternatively unscrew the holding part on the fork with 3mm hex key
  30. E-bike Disassembly of frame for painting (model: HNF UD1), Remove the front fork (and wheel): step 30, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the front fork (and wheel): step 30, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove the front fork (and wheel): step 30, image 3 of 3
    • Remove - if any - protective/design rubber cap on stem
    • Loosen the stem with a 5mm allen key.
    • Loosen the two bolts on the side of the stem with the 5mm allen key
  31. E-bike Disassembly of frame for painting (model: HNF UD1): step 31, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 31, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 31, image 3 of 3
    • Carefully lift the handle bar off the fork
    • Lift the two consecutive spacers off
    • Lift off the bearing cap
  32. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearings: step 32, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearings: step 32, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearings: step 32, image 3 of 3
    • Remove upper bearing
    • The flat part must be facing upwards, the cornered part downwards into the frame
    • The lower bearing can be left on the front fork
  33. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Nuvinci shift cables: step 33, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Nuvinci shift cables: step 33, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Nuvinci shift cables: step 33, image 3 of 3
    • shift pedals to a position that allows easy access to the shift cable hardware
    • Remove the shift cable hardware ends
    • Open the securing closing mechanism on the lower one (open and lift)
    • Remove the cable end from its socket
  34. E-bike Disassembly of frame for painting (model: HNF UD1): step 34, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 34, image 2 of 2
    • Remove the upper cable's end from its socket
    • The cable with no closing mechanism comes on the top part, and the closing mechanism closes in from the bottom on the top
  35. E-bike Disassembly of frame for painting (model: HNF UD1), Remove rear wheel: step 35, image 1 of 1
    • Loosen the bolts with the 15mm wrench on both sides of the rear axel
    • Remove the rear wheel carefully, not to damage the belt!
  36. E-bike Disassembly of frame for painting (model: HNF UD1), Disassemble the frame: step 36, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Disassemble the frame: step 36, image 2 of 2
    • Remove rear facing bolt with 5mm allen key
  37. E-bike Disassembly of frame for painting (model: HNF UD1): step 37, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 37, image 2 of 2
    • Slide the black part out of the frame (pointy part faces backwards)
  38. E-bike Disassembly of frame for painting (model: HNF UD1): step 38, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 38, image 2 of 2
    • To remove the bolt that held the long screw and black part in place,
    • use a small but long tool (nail or screwdriver) and put it in the hole, where the removed screw was previously, but not through the upper part of the frame, but diagonally from the outside - thus the bolt can be slightly pushed out of the frame
    • Grab this slightly outlying bit with a plier and pull it out
  39. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bike rack (after light cable released): step 39, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bike rack (after light cable released): step 39, image 2 of 2
    • Do not remove the bike rack (the mud guard) while the back light is still attached to the motor!
    • Loosen the two bolts on the rear part of the frame with 4 mm allen key
  40. E-bike Disassembly of frame for painting (model: HNF UD1): step 40, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 40, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 40, image 3 of 3
    • The Bolt has multiple plates:
    • a metal plate below the bolt head
    • a cornered black plate , then comes the bike rack
    • one metal between the bike rack and the frame
    • Main goal is to strip everything from the frame, thus the rest of the bike racks screws do not have to be removed, since the complete bike fender must be removed
  41. E-bike Disassembly of frame for painting (model: HNF UD1), Remove The Rear Fender from the frame: step 41, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove The Rear Fender from the frame: step 41, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove The Rear Fender from the frame: step 41, image 3 of 3
    • Remove the two screws holding it to the frame's middle (back frame's triangle's corners)
    • There are two (1-1) black plastic/rubber plates between the fender and the frame on the screws
    • In total the bike rack and rear fender are connected with 4 screws to the frame
  42. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Belt: step 42, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Belt: step 42, image 2 of 2
    • Carefully remove the Belt through the frame
    • Watch out not to bend the belt, or damage it in any way
  43. E-bike Disassembly of frame for painting (model: HNF UD1), Storeing the Belt: step 43, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Storeing the Belt: step 43, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Storeing the Belt: step 43, image 3 of 3
    • For storage purpose you can coil the belt by holding it on the two sides, and turning one hand inwards, the other outwards.
    • If you feel resistance, STOP!
    • It should coil easily (in three loops)
    • This video shows the process: https://www.youtube.com/watch?v=VgM-qeHG...
    • Uncoiling: find the outermost circle, and slowly start to straighten it out. The Belt will uncoil on its own
    • Uncoiling the belt: https://www.youtube.com/watch?v=slFf0q1I...
  44. E-bike Disassembly of frame for painting (model: HNF UD1), Remove bike stand: step 44, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove bike stand: step 44, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove bike stand: step 44, image 3 of 3
    • Loosen the two front facing bolts with the 5mm hex key
    • Curved side must face backwards (obviously, as the stand must look backwards...)
  45. E-bike Disassembly of frame for painting (model: HNF UD1), Remove rear wheel holder: step 45, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove rear wheel holder: step 45, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove rear wheel holder: step 45, image 3 of 3
    • Remove the longer front facing screws (with neck) from the rear end on both sides with 4 mm hex key
    • those setting the tightness of the belt by adjusting the position of the wheel holder
  46. E-bike Disassembly of frame for painting (model: HNF UD1): step 46, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 46, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1): step 46, image 3 of 3
    • Cut the zip ties holding the brake cable on the frame with a wire cutter or remove other fixating elements
    • Remove the screws on both sides (2x2) holding the wheel holder in place with 6mm hex key
    • The plate comes between the bolt head and the frame!
  47. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch speed sensor: step 47, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch speed sensor: step 47, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Bosch speed sensor: step 47, image 3 of 3
    • Remove the rubber cap by hand
    • Remove the locking screw with a T20 torx screwdriver
    • The speed sensor's cable is going through the frame
  48. E-bike Disassembly of frame for painting (model: HNF UD1), Rear Brake cable: step 48, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Rear Brake cable: step 48, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Rear Brake cable: step 48, image 3 of 3
    • The rear break levers' "cable" (on the right) is tied together with the Intuvia board computers fat cabel and goes down the frame on the right side
    • After the Battery, it crosses and exits the black part on the left side (as single cable) and goes on the top part of the rear frame
  49. E-bike Disassembly of frame for painting (model: HNF UD1), NuVinci gear shifter cable setup: step 49, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), NuVinci gear shifter cable setup: step 49, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), NuVinci gear shifter cable setup: step 49, image 3 of 3
    • The NuVinci gear shifter is on the right side.
    • The cables are tied together with the supernova lamp's thin cable (in comparison to Intuvias thicker cable) .
    • These cables go down on the left side of the frame. Then cross under the black part below the battery and exit on the right side (only the two Nuvinci cables from here). Then it goes down to the inner part of the frame's back triangle and has three plastic holders.
  50. E-bike Disassembly of frame for painting (model: HNF UD1): step 50, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1): step 50, image 2 of 2
    • Remove the 3x screws, keeping the cable holders in place, with a 3mm hex key
    • The frame is upside down for easier work conditions on the image
  51. E-bike Disassembly of frame for painting (model: HNF UD1), Remove cable guide and black design cover holder plate: step 51, image 1 of 2 E-bike Disassembly of frame for painting (model: HNF UD1), Remove cable guide and black design cover holder plate: step 51, image 2 of 2
    • Underlying metal holder (and cable aligner) is held in place by a 3mm hex screw
    • A big diametered washer is under the screw head
    • Below is the placeholder
  52. E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearing holders: step 52, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearing holders: step 52, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove Front fork bearing holders: step 52, image 3 of 3
    • The one on top has sharper corners
    • The one on the bottom is fully rounded
    • They can either be removed with a specific tool, or with a chisel and a hammer (possibly rubber hammer)
    • Be careful with this step not to damage the rings inner side - might even ask for the help at a local bike shop
  53. E-bike Disassembly of frame for painting (model: HNF UD1), Remove screw hole changers: step 53, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove screw hole changers: step 53, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Remove screw hole changers: step 53, image 3 of 3
    • Before painting the fork these small parts can be removed with a wide flat head screwdriver (8), but do not have to necessarily
    • This step can be skipped, especially, because these can easily be damaged, and are sometimes difficult to remove
  54. E-bike Disassembly of frame for painting (model: HNF UD1), Prepare for painting: step 54, image 1 of 1
    • Check with paint shop if the wholes should be protected
    • If needed - insert (short) screws in all places, where there were any before, to save their guideway (14 small type screws, 7 bigger type)
    • And the frame is ready for a fresh new paint!!!
  55. E-bike Disassembly of frame for painting (model: HNF UD1), Additional empty wholes: step 55, image 1 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Additional empty wholes: step 55, image 2 of 3 E-bike Disassembly of frame for painting (model: HNF UD1), Additional empty wholes: step 55, image 3 of 3
    • There are 2x2 unused bolts on either (inner) side of the frames back triangles top tube
    • Additional two unused bolts are just over the rear fender facing slightly upward
To reassemble your device, follow these instructions in reverse order. Except for the nuvinci cable setting - this has to be adjusted at the end, when the back wheel is set to the right position and belt tension
Bango Bejla
1,357 Reputation
6 Guides authored
2 Comments
Do you have any photos of the frame after it's been painted?
Rares Alexandru Murza - Reply
Yes, I updated the main picture to show the frame after the paint job :)
Bango Bejla -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 41
All Time: 481
