ECAM 350.55 Test mode
  1. ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 1 of 3 ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 2 of 3 ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 3 of 3
    • When the machine is switched on, press the off-switch until the machine goes into standby mode and the display turns off.
    • There has to be water in the water tank, the drip tray is initially still inserted. The power plug remains in the outlet.
  2. ECAM 350.55 Test mode: step 2, image 1 of 2 ECAM 350.55 Test mode: step 2, image 2 of 2
    • Pull the drip tray out a little, a corresponding message will appear on the display. (In the picture in English)
  3. ECAM 350.55 Test mode: step 3, image 1 of 3 ECAM 350.55 Test mode: step 3, image 2 of 3 ECAM 350.55 Test mode: step 3, image 3 of 3
    • First press and hold the ESC button, then press and hold the remaining three buttons in the other corners simultaneously.
    • SELECT TEST MODE" will appear on the display. Push the drip tray back in
    • Press the "DRINK MENU" button
  4. ECAM 350.55 Test mode: step 4, image 1 of 3 ECAM 350.55 Test mode: step 4, image 2 of 3 ECAM 350.55 Test mode: step 4, image 3 of 3
    • You can now test various functions:
    • Brew group up/brew group down
    • Ev2 = solenoid valve2 clicks (upper 3-way valve)
    • Ev1 = solenoid valve1 clicks (lower 3-way valve)
    • Grinder is running
    • Coffee heater gets hot
    • Steam heater
    • Pump is running
Work through the steps in reverse order to reassemble your device.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
299,140 Reputation
303 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
32 Members
1,571 Guides authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 103
Past 30 Days: 590
All Time: 10,456
