EDCO Floor Stripper TS8 .75L (2017) Belt Replacement
  1. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: step 2, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: step 2, image 2 of 2
    • Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
    • During reassembly, ensure each bolt is reinstalled with both its flat washer and lock washer.
  3. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: step 3, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: step 3, image 2 of 2
    • Pull the hood away from the device to remove it.
  4. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: step 4, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: step 4, image 2 of 2
    • Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
  5. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: step 5, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: step 5, image 2 of 2
    • Slide the motor towards the front of the device to release tension in the belt."
    • Reassembly tip: Tilt the device onto its handles to use the weight of the motor to tension the belt, then tighten down the bolts.
  6. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: step 6, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: step 6, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: step 6, image 3 of 3
    • Remove the belt from the cam shaft pulley.
  7. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: step 7, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: step 7, image 2 of 2
    • Disengage the belt from the motor pulley.
    • Remove the belt.
Robert Boyd
27,179 Reputation
94 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 443
