EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement
  1. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Safety precautions: step 1, image 1 of 1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the screw from the red knob: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
  3. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the knob: step 3, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the knob: step 3, image 2 of 2
    • Remove the red knob.
    • This component is keyed. During reassembly, ensure it is reinstalled in the correct orientation.
  4. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the black cap: step 4, image 1 of 1
    • Remove the black plastic cap from the center of the switch assembly.
  5. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
    • During reassembly, ensure this component is installed in the same orientation, with the circle in the 6 o'clock OFF position.
  6. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 6, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 6, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 6, image 3 of 3
    • Remove the yellow switch guide from the switch assembly.
    • Remove the black plastic spacer from underneath the yellow switch guide.
  7. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the upper switch housing: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
    • These screws may not come out of their recesses in the housing once they are completely unthreaded. If some stay inside once loose, don't lose track of them.
  8. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 8, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 8, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 8, image 3 of 3
    • Lift the upper half of the switch housing off of the lower half."
    • The rubber gasket may fall out of the upper housing during the removal process. Do not forget to reinstall the gasket upon reassembly.
  9. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Disconnect the power cord from the frame: step 9, image 1 of 1
    • Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
  10. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the loom clamp: step 10, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the loom clamp: step 10, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the loom clamp: step 10, image 3 of 3
    • Remove the loom clamp from the power cable.
  11. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the switch housing: step 11, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the switch housing: step 11, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the switch housing: step 11, image 3 of 3
    • Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
    • During reassembly, use a Phillips screwdriver in combination with the 11/32 inch socket wrench to tighten the bolts securing the switch to the bracket."
  12. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 12, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 12, image 2 of 2
    • Lift the switch assembly off of the switch bracket.
    • The switch housing bolts may fall out when you remove the housing.
  13. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Disconnect the green wires: step 13, image 1 of 1
    • Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
  14. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 14, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 14, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 14, image 3 of 3
    • Separate the green ground wires from each other and move them away from the switch housing.
  15. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Disconnect the power cord from the switch: step 15, image 1 of 1
    • Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
    • During reassembly, ensure each wire is installed in its correct location on the switch.
  16. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 16, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 16, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 16, image 3 of 3
    • Remove the black wire from the switch.
  17. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 17, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 17, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 17, image 3 of 3
    • Remove the white wire from the switch.
  18. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 18, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 18, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 18, image 3 of 3
    • Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
    • Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
  19. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the power cord: step 19, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the power cord: step 19, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the power cord: step 19, image 3 of 3
    • Remove the power cord from the on/off switch.
  20. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Remove the on/off switch: step 20, image 1 of 1
    • Use a flathead screwdriver to loosen the two screws securing the wiring harness's black and white wires to the switch.
  21. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 21, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 21, image 2 of 2
  22. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 22, image 1 of 2 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 22, image 2 of 2
  23. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 23, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 23, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 23, image 3 of 3
    • Use a 1-1/16 inch wrench or an adjustable wrench to loosen the wiring harness cable's strain relief fitting from the switch housing.
    • Once the fitting is loose enough to turn by hand, twist the wiring harness cable and fitting counterclockwise until it is fully unthreaded from the switch housing.
    • You may need to rotate the switch assembly itself since the wiring harness cable is connected to the device, preventing it from rotating freely.
  24. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 24, image 1 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 24, image 2 of 3 EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement: step 24, image 3 of 3
    • Remove the on/off switch from the auxiliary cable.
  25. EDCO Floor Stripper TS8 .75L (2017) On/Off Switch Replacement, Reassembly tip: step 25, image 1 of 1
    • Reassembly tip: ensure the replacement switch is labeled with the correct stickers, matching the old part."
Robert Boyd
27,179 Reputation
94 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 311
