Introduction
Follow this guide to replace the throttle cable assembly on an EDCO PRO Walk Behind Concrete Saw model KL-18 39600-HD.
Chock the wheels to prevent the machine from moving while you are working on it.
Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a short Phillips screwdriver to remove the screw securing the throttle cable holder.
Grip the black throttle control knob and pull it straight up and off of the control lever to remove it.
