EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement
    • If you have any dust caps over the HDMI or Display Port connections, remove them
  1. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Remove Back Screws: step 2, image 1 of 1
    • Remove the 3 screws using a Phillips #1 Screwdriver (Red)
    • Remove the 2 Standoffs using a 5mm socket
  2. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement: step 3, image 1 of 2 EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement: step 3, image 2 of 2
    • Remove top screw using a Phillips #0 screwdriver (Blue)
    • Remove the bottom screw and nut using a Phillips #0 screwdriver. Will want to use a finger to hold the nut from spinning while releasing the screw.
    • Gently slide the plate out from between the back cover and the circuit board. It should come out without much force.
    • If it doesn't want to budge, check that the right screw was removed from the top of the video card.
  3. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Remove 4 Screws: step 5, image 1 of 2 EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Remove 4 Screws: step 5, image 2 of 2
    • Using the 1.5mm Hex, remove the 4 screws (one on each corner) to release the shroud
    • Note: there is 4 screws on each corner plate, the other 3 screws do not need to be removed.
  4. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Open the shroud: step 6, image 1 of 2 EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Open the shroud: step 6, image 2 of 2
    • The shoud should be able to be lifted free easily, on the wiring harness for the lights.
    • The connector for the harness is on the inside end end, nearest the power connectors.
    • The connector can be disconnected to completely seperate the shroud, or left connected if just needing access to the fans.
  5. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Remove the 3 screws: step 7, image 1 of 1
    • Using the #1 Phillips Screwdriver, reach between the fins to unscrew the 3 screws holding the fan to the heatsink.
  6. EVGA GeForce GTX 1080 FTW2 DT GAMING with iCX Cooler PCIe Video Card Fan Replacement, Detach the wiring harness: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • The wiring harness goes under the Blue clip and pulling the wire down will alow it to come free.
    • The Red box is where the connector is located on the circuit board.
    • Use the Tweezers to gently disconnect the connector.
    • Installing the new fan, I found it easier to connect the wiring first, then the fan itself
    • Connect the connector (the keying points away from you)
    • Seat the cable under the metal clip
    • Screw in the 3 screws for the fan
    • Loosely screw in all 3 screw before screwing them down tight.
    • Careful to not damage the fan blade, as that would cause premature wear and excess noise.
Wolphin
1,725 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,942
