EVGA x17 Clicker Replacement
  1. EVGA x17 Clicker Replacement, Clicker: step 1, image 1 of 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Clicker Replacement: step 2, image 1 of 1
    • Use a Phillips head screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Clicker Replacement: step 3, image 1 of 1
    • Remove the weight chamber cover.
  4. EVGA x17 Clicker Replacement: step 4, image 1 of 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Clicker Replacement: step 5, image 1 of 2 EVGA x17 Clicker Replacement: step 5, image 2 of 2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Clicker Replacement: step 6, image 1 of 1
    • Carefully slide the middle section out.
  7. EVGA x17 Clicker Replacement: step 7, image 1 of 1
    • Remove the two screws from each clicker.
  8. EVGA x17 Clicker Replacement: step 8, image 1 of 1
    • Pop and slide out each clicker that needs to be replaced.
    • Clickers may need to be tugged forward in their slots to slide out.
    • Be extra careful removing clickers because the attachments are fragile.
1 Guide Comment
Tengo un Evga x17 y cuando quitó los sliders, encuentro unas pequeñas capas de plástico que tapan el acceso a los tornillos, ¿qué puedo hacer en ese caso?
Dennis Lopez - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 377
