Earth-leakage circuit breaker in meter cabinet engaged
  1. Earth-leakage circuit breaker in meter cabinet engaged, Grill heating element: step 1, image 1 of 1
    • The symptom is that de earth leakage circuit breaker in the meter cabinet engages if one opens the oven door.
  2. Earth-leakage circuit breaker in meter cabinet engaged, Inspect the grill heating element: step 2, image 1 of 1
    • Open the oven door en illuminate the ceiling of the oven using a flash light.
    • If the glass of a heating element is broken (see photo), a short circuit towards the metal enclosement occurs.
  3. Earth-leakage circuit breaker in meter cabinet engaged, Replacing the grill heating element: step 3, image 1 of 2 Earth-leakage circuit breaker in meter cabinet engaged, Replacing the grill heating element: step 3, image 2 of 2
    • Replacement elements are available for approx 30..40 euro's per piece at various online shops.
    • Wires with cable clamps attach to the heating elements. These can be removed by removing the plastic sleeve, followed by pressing a little pin while pulling the clamp.
    • Gently push/shift the old element out of the oven. Make sure no broken glass particles are left behind. Install the new element.
    • If the short-circuit is hard to find, then it can be handy to use a current clamp meter in combination with an external DC power supply.
To assemble the oven, follow the disassembly instructions in reverse order.
Special thanks to these translators:
nl en
100%
Roland is helping us fix the world! Want to contribute?
Start translating ›
Roland
450 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 74
