EasySMX X15 Bottom Casing Replacement
  1. EasySMX X15 Bottom Casing Replacement, Bottom Casing: step 1, image 1 of 2 EasySMX X15 Bottom Casing Replacement, Bottom Casing: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
    • Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
    • Be gentle when separating the lower casing from the upper casing to avoid breaking any of the plastic snap tabs.
ShawnDetiveaux
646 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 232
