Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement
  1. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: step 1, image 1 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: step 1, image 2 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the spark plug wire: step 1, image 3 of 3
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: step 2, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Disconnect the control cables: step 2, image 2 of 2
    • Unclip the throttle cable routing clip from the main shaft.
  3. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 3, image 1 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 3, image 2 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 3, image 3 of 3
    • Grip both ends of one of the control cable bullet connectors and pull to disconnect it.
    • Repeat to disconnect the second control cable connector.
    • These connectors are interchangeable.
  4. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: step 4, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the muffler cover: step 4, image 2 of 2
    • This Echo device has an included multi-tool with a T30 Torx screwdriver, but any T30 Torx driver is compatible.
    • Use a T30 Torx driver to remove the two screws securing the muffler cover.
  5. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 5, image 1 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 5, image 2 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 5, image 3 of 3
    • Lift the muffler cover up and pivot it on its top edge to unlatch it from the engine cover.
    • Remove the muffler cover.
  6. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: step 6, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the engine cover: step 6, image 2 of 2
    • Use a T30 Torx driver to remove the two screws securing the engine cover.
  7. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 7, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 7, image 2 of 2
    • Lift the engine cover straight up to remove it.
  8. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the fan cover: step 8, image 1 of 1
    • Use a T30 Torx driver to remove the two screws securing the fan cover.
  9. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 9, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 9, image 2 of 2
    • Pull the fan cover away from the motor assembly.
  10. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: step 10, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Reassembly tip: step 10, image 2 of 2
    • During reassembly:
    • Reroute the two control cables through the opening on the fan cover.
    • Lay the cables into their slot on the clutch cover.
  11. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Separate the shaft from the engine assembly: step 11, image 1 of 1
    • Use a T30 Torx driver to loosen, but not remove, the collar bolt securing the main shaft to the engine assembly.
  12. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 12, image 1 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 12, image 2 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 12, image 3 of 3
    • Grip the engine assembly and pull to remove it from the main shaft.
    • With the engine assembly removed, take care to not put any strain on the still-connected throttle cable.
  13. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch cover: step 13, image 1 of 1
    • Use a T30 Torx driver to remove the two screws securing the clutch cover.
  14. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 14, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 14, image 2 of 2
    • Remove the clutch cover.
  15. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch assembly: step 15, image 1 of 1
    • Use a 1/2 inch socket to remove the two 12 mm-long bolts and four accompanying washers securing the clutch assembly.
    • Note that the larger washer goes underneath the clutch assembly and the small washer goes above.
    • Ensure that the clutch assembly is reinstalled arrow side up.
  16. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 16, image 1 of 2 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 16, image 2 of 2
    • Remove the clutch assembly.
  17. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: step 17, image 1 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: step 17, image 2 of 3 Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement, Remove the clutch spring: step 17, image 3 of 3
    • Firmly grip one clutch shoe in each hand and twist them apart to release the spring tension.
    • During reassembly, loop the clutch spring in place on the clutch shoes and twist them together to reapply spring tension.
    • Disconnect one side of the spring loop from one of the clutch shoes.
  18. Echo Brushcutter SRM2620U 2017 Clutch Spring Replacement: step 18, image 1 of 1
    • Remove the spring from the remaining clutch shoe.
Carsten Frauenheim
135,464 Reputation
371 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 188
