Echo Chain Saw CS590 2019 Ignition Assembly Replacement
  1. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Turn off the chainsaw: step 1, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Turn off the chainsaw: step 1, image 2 of 2
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Loosen the air filter cover: step 2, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Loosen the air filter cover: step 2, image 2 of 2
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 3, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 3, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 3, image 3 of 3
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Disconnect the spark plug: step 4, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Disconnect the spark plug: step 4, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Disconnect the spark plug: step 4, image 3 of 3
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the air filter: step 5, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the air filter: step 5, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the air filter: step 5, image 3 of 3
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the front handle: step 6, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the front handle: step 6, image 2 of 2
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the front handle: step 7, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the front handle: step 7, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the front handle: step 7, image 3 of 3
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the sprocket guard: step 8, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the sprocket guard: step 8, image 2 of 2
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 9, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 9, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 9, image 3 of 3
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the guide bar: step 10, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the guide bar: step 10, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the guide bar: step 10, image 3 of 3
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the front hand guard: step 11, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the front hand guard: step 11, image 2 of 2
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the front hand guard: step 12, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the front hand guard: step 12, image 2 of 2
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the engine cover: step 13, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the engine cover: step 13, image 2 of 2
    • Use a T25 Torx screwdriver to remove the three 20 mm screws securing the engine cover.
  14. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the engine cover: step 14, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the engine cover: step 14, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the engine cover: step 14, image 3 of 3
    • Pull the engine cover straight off the device to remove it.
  15. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the starter case: step 15, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the starter case: step 15, image 2 of 2
    • Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
  16. Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 16, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 16, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 16, image 3 of 3
    • Remove the starter case.
  17. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the spark plug cable: step 17, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the spark plug cable: step 17, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the spark plug cable: step 17, image 3 of 3
    • Use your fingers to reroute the spark plug cable from its slot in the fan cover.
  18. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the ignition coil cable: step 18, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the ignition coil cable: step 18, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Reposition the ignition coil cable: step 18, image 3 of 3
    • Use your fingers to reroute the ignition coil cable from its slot in the fan cover.
  19. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Disconnect the ignition coil: step 19, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Disconnect the ignition coil: step 19, image 2 of 2
    • Use pliers, or your fingers, to disconnect the ignition coil cable's spade connector.
    • Grip the connector by the base of the clear head and not the wire itself.
  20. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the ignition coil: step 20, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the ignition coil: step 20, image 2 of 2
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the ignition coil.
    • During reassembly, insert the ignition air gap gauge to ensure a 0.35 mm space between the coil and the magnet.
  21. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the ignition coil: step 21, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the ignition coil: step 21, image 2 of 2
    • Remove the ignition coil.
  22. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the flange nut: step 22, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the flange nut: step 22, image 2 of 2
    • Wedge a flathead screwdriver between the chassis and the flywheel's spokes to prevent the flywheel from spinning.
    • Alternatively, you can seize the piston by inserting a rope down the spark plug shaft.
    • Use a 13 mm wrench to loosen and remove the flange nut located in the middle of the flywheel.
  23. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the starter pawls: step 23, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the starter pawls: step 23, image 2 of 2
    • Use a T25 Torx screwdriver to remove the two 16 mm screws securing the starter pawls.
    • Remove the starter pawls.
  24. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Starter pawl assembly information: step 24, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Starter pawl assembly information: step 24, image 2 of 2
    • During reassembly, be sure to reinstall the starter pawl assembly top to bottom in the following order:
    • 16 mm screw
    • Washer
    • Starter Pawl
    • Spacer
    • Torsion Spring
  25. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the flywheel: step 25, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Unfasten the flywheel: step 25, image 2 of 2
    • Use a flywheel puller to disconnect the flywheel from the woodruff key.
  26. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the flywheel: step 26, image 1 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the flywheel: step 26, image 2 of 3 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the flywheel: step 26, image 3 of 3
    • Pull the flywheel straight off of the crankshaft and remove it.
  27. Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the woodruff key: step 27, image 1 of 2 Echo Chain Saw CS590 2019 Ignition Assembly Replacement, Remove the woodruff key: step 27, image 2 of 2
    • Insert a flathead screwdriver into the gap at the top of the woodruff key.
    • Pry with the screwdriver to separate the key from the crankshaft.
  28. Echo Chain Saw CS590 2019 Ignition Assembly Replacement: step 28, image 1 of 1
    • Use pliers, or your fingers, to remove the woodruff key.
    • During reassembly, be sure to reinsert the woodruff key with the flat side facing outward.
Alex Diaz-Kokaisl
127,879 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 97
All Time: 879
