Echo Chain Saw CS590 2019 Starter Assembly Replacement
  1. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Turn off the chainsaw: step 1, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Turn off the chainsaw: step 1, image 2 of 2
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Loosen the air filter cover: step 2, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Loosen the air filter cover: step 2, image 2 of 2
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 3, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 3, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 3, image 3 of 3
    • Remove the air filter cover.
  4. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Disconnect the spark plug: step 4, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Disconnect the spark plug: step 4, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Disconnect the spark plug: step 4, image 3 of 3
    • Use your fingers to pull up and disconnect the spark plug boot.
  5. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the air filter: step 5, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the air filter: step 5, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the air filter: step 5, image 3 of 3
    • To minimize debris entering the intake, pull the choke shut before continuing.
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  6. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the front handle: step 6, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the front handle: step 6, image 2 of 2
    • Use a T25 Torx screwdriver to remove the five screws securing the front handle to the bottom and right side of the device:
    • Four 24 mm-long screws
    • One 25 mm-long screw
  7. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the front handle: step 7, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the front handle: step 7, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the front handle: step 7, image 3 of 3
    • Pull the handle toward the rear of the device to remove it.
  8. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the sprocket guard: step 8, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the sprocket guard: step 8, image 2 of 2
    • Use a 13 mm wrench to remove the two nuts securing the sprocket guard.
  9. Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 9, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 9, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement: step 9, image 3 of 3
    • Remove the sprocket guard.
  10. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the guide bar: step 10, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the guide bar: step 10, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the guide bar: step 10, image 3 of 3
    • Push the guide bar towards the back of the device to create slack in the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar.
  11. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the front hand guard: step 11, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the front hand guard: step 11, image 2 of 2
    • Make sure the front hand guard is in the unlocked position before continuing.
    • Use a T25 Torx screwdriver to remove the two 20 mm screws securing the front hand guard.
  12. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the front hand guard: step 12, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the front hand guard: step 12, image 2 of 2
    • Pull the front hand guard toward the rear of the device to remove it.
  13. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the starter case: step 13, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the starter case: step 13, image 2 of 2
    • Use a T25 Torx screwdriver to remove the four 24 mm screws securing the starter case.
  14. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter cover: step 14, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter cover: step 14, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter cover: step 14, image 3 of 3
    • Pull the starter cover straight off its housing to remove it.
  15. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the starter plate: step 15, image 1 of 2 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Unfasten the starter plate: step 15, image 2 of 2
    • Use a T25 Torx screwdriver to remove the three screws securing the starter plate:
    • Two 15 mm-long screws
    • One 14 mm-long screw
  16. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter plate: step 16, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter plate: step 16, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter plate: step 16, image 3 of 3
    • Be very careful with this step, as there's a lot of tension in the recoil spring. If you remove the starter plate too quickly, you may unravel the coil.
    • Carefully lift the starter plate straight out of its recess and remove it.
  17. Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter grip: step 17, image 1 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter grip: step 17, image 2 of 3 Echo Chain Saw CS590 2019 Starter Assembly Replacement, Remove the starter grip: step 17, image 3 of 3
    • Use pliers, or your fingers, to pull the rope knot out of the top of the starter grip.
    • Undo the knot and remove the grip.
Alex Diaz-Kokaisl
127,879 Reputation
592 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
One Comment
Although safety is foremost when I work, steps 2 through 12 are not really necessary. Step 1 is important for sure but then all you need to do to before Step 13 is to remove the screw near the upper-left of the Starter Case holding the Front Hand Guard in place and pull the Guard up and away from the Starter Case.
HANS - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 48
All Time: 496
