Introduction
Use this guide to remove or replace the fan clutch drum in an Echo Power Pruner 254 cc PPT2620 2019.
Use a T25 Torx screwdriver to loosen (but not remove) the two screws clamping the main pipe assembly to the control handle.
Remove seven T25 screws holding together the control handle.
Use a T25 Torx screwdriver to loosen (but don't remove) the screw clamping the strap hook to the handle pipe.
Remove the two T25 screws securing the handle to the handle pipe.
Lift the control wires out of their slots in the handle.
Lift the throttle cable out of its slots in the handle.
Lift the driveshaft straight out of the handle pipe and remove it.
5 other people completed this guide.
