Eclipse 180BL LCD Screen Cover Replacement
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: step 1, image 1 of 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: step 1, image 2 of 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: step 1, image 3 of 3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: step 2, image 1 of 3 Eclipse 180BL LCD Screen Cover Replacement: step 2, image 2 of 3 Eclipse 180BL LCD Screen Cover Replacement: step 2, image 3 of 3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Thomas Schwarz
499 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 734
