Eclipse 180BL Touch Pad Replacement
  1. Eclipse 180BL Touch Pad  Replacement, Touch Pad: step 1, image 1 of 1
    • Remove the two screws at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair toolkit.
    • The two screws are 1/8 inch in length.
    • Remove the cover to reveal the internal component.
  2. Eclipse 180BL Touch Pad  Replacement: step 2, image 1 of 3 Eclipse 180BL Touch Pad  Replacement: step 2, image 2 of 3 Eclipse 180BL Touch Pad  Replacement: step 2, image 3 of 3
    • Using the Spudger, forcefully push upward on the USB port of the device to remove the main component.
    • This will release the tension on the multiple parts. One of which will be the touch pad.
    • The touch pad can now be easily replaced.
    • The touch pad has a smaller center piece that must be replaced for proper usage of the device.
Thomas Schwarz
499 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 844
