Eclipse 180G2 Outer Case Replacement
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: step 1, image 1 of 2 Eclipse 180G2 Outer Case Replacement, Outer Case: step 1, image 2 of 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 1 of 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 2 of 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: step 2, image 3 of 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
3 other people completed this guide.
Jesse Minor
662 Reputation
3 Guides authored
USF Tampa, Team 1-4, Tanski Winter 2015 Member of USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Members
5 Guides authored
One Comment
What if there is no charge port or USB port there no longer?
May 303 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,361
